Why does alum tube make turbo louder?
Old Apr 6, 2005 | 08:20 PM
trik396's Avatar
Just have some questions on why these home-made torque tubes produce more turbo whisle than the stock setup? Is it because the aluminum or steel tubing creates a more tinny sound or is it just allowing more of the turbo sound to get thru more-so than the oem plastic?
I like the stock turbo sound and would like to hear more of it.... but I don't want to much of a good thing. Should I or not?
Old Apr 6, 2005 | 09:59 PM
jkitterman's Avatar
the piece that looks like it has a cross in it is designed to cut down on the noise. Almost all truck have them. If the truck is heavy enough, you just did a bid NO, NO...tampering with a noise control device.
Old Apr 6, 2005 | 10:00 PM
SjLingenfelter's Avatar
If you look inside that Torque tube...There is some plastic grates it looks like.That is why its louder cause those grats arent in there
Old Apr 7, 2005 | 02:40 AM
doug's Avatar
I found little to no increase in turbo whistle going from the stock intake tube to the AFE plastic tube. the AFE tube has no baffles. the metal tubes are definately louder -- must be resonance. some have quieted down the metal intake tube with sound absorbing or damping material
Old Apr 7, 2005 | 03:26 AM
John Rodriguez's Avatar
Tire Hater
Why would anyone do such a thing...
Old Apr 7, 2005 | 06:18 AM
Sometimes when ur towin a trailer for a couple days your ears start to hurt Goin to Colorado in july and were towin a 14000# 4 horse trailer...14k is unloaded.
turboman05
16
Jan 20, 2010 11:36 PM
sgrooms
21
Apr 8, 2008 11:17 AM
Robman
Mar 18, 2008 09:59 PM
Dean Snow
Sep 21, 2007 01:18 PM
LibertyCRD
Nov 12, 2005 12:15 AM
