Why do the doors shake at high speeds?
Everytime I go above 80mph, the doors start shaking as if the windows arent closed or the doors are closed. I mean, its a really embarassing feeling when I have buddies in my truck and I do go over 80mph ever. That feeling also happens when its windy as well.
I mean I feel the doors like literally about to come off, like wind goes through them. Its the feeling when you have the window cracked a little open. It might be the tires, as much as I like the tires, ride really sucks above 60mph
Ive had several sets of swampers, several different series of them and your having tire problems. I would go see if you can have them rebalanced. But I have heard that some cannot be balanced.
you need to have a good speed balancer do it. there is only one place in san antonio that I would have it done and it sure as heck isnt discount tire or a local tire shot. it is a place called southwest brake and alignment, they balance while the tire is on the vehicle. Generally this is what you would want to do on a meatier tire or a tire over 35".
my driver side door does the same thing try putting a very very small crack in your window this is the only way i can stop the noise. it has nothing to do with your tires. i think these trucks have bad door seals or sumthin.
