where to find info on quadzilla products
Yeah, this site. Somebody asked the exact same question, and Quad spelled it out. In general, you get some power from all aspects at each setting, but the amount from each aspect changes depending on the setting. Exact numbers I don't remember.
Originally Posted by bluebull
Does anyone have pictures of the switch used to go through different power levels or describe it?
The 2 small buttons in the middle control the different power levels for the XZT, or any other mod. If you look at the right side of screen between FUEL and TRANS, you see the circle with the 0 in it, it's on 0 now because the engine water temperature is under 160*, it turns on after the engine Temp gos over 160*, I believe I had it set on 160*, you can adjust it for what ever temp you want it to turn on.
Al,
So your saying the power levels come on according to what I would set the engine coolant temperature at.
Cool.
Any other special features about the Commander to help decide to buy one.
Any and all information about the Commander or XZT tow module is greatly appreciated.
I e-mailed qzilla a few questions.
Thanks to everyone who has contributed to this thread. I feel it's a great way to learn from those who have experienced a product.
Thanks Again,
Ron
Cool.
Thanks Again,
Ron
Tons of features, brother. It will flash warnings when preset parameters are met, such as engine coolant temp, EGTs, boost, tranny temp and fuel pressure. Then, if you fail to heed these warnings it will defuel at another preset parameter. For example, I have mine set to warn me when EGTs hit 1350*, then it will automatically defuel if I continue and push it and they hit 1400*. It will do the same for tranny temp, coolant temp, fuel pressure, and boost.
Xzillaraider Standard:
1. What are the power levels?
2. how are the levels changed or controled?
3. stand alone unit or need commander?
0-30-60-100 rwhp gain
With a digital "control pod" We do not use the switches anymore.
Works stand alone or with the Commander, completely up to you. Also upgradeable in the future to the Commander
Xzillaraider Race:
2. How are the levels changed or controled?
3. Stand alone unit or need commander?
Commander:
1. Can it read and clear DTC codes?
Not yet.
I was told I can make the XZT adjustable with the commander. Is this true and if yes what levels are there in the XZT.
Yes.
0-25-45-65hp
Now I've gone brain dead,
I'll think of more questions later.
Thanks,
Xzillaraider Race:
Commander:
Not yet.
Yes.
0-25-45-65hp
I'll think of more questions later.Thanks,
I'll be the last one to tell anyone on how to run a business but if more of this information was on quadzilla's website they would probably sell alot more units.
Makes me wonder how many more features these things have and don't know about.
Keep them coming guys, this is great info.
sheriffav8r
21
Feb 24, 2009 12:35 PM
kevinv
May 24, 2008 08:44 PM
mkelly9779
Apr 14, 2008 11:04 PM
jpfishmaster
Jan 17, 2008 09:31 PM
subspd
May 20, 2007 10:15 PM
