What are you stacking with your Smarty?
Old Sep 6, 2008 | 10:19 AM
ohyeahfriday's Avatar
Question What are you stacking with your Smarty?
I am considering a change and was wondering what others are stacking with the Smarty.
Please post the following; what you are stacking, how you like it, any plans of switching to something else?
I am currently running the Diablo Puck with mine, and am looking for something else to compare to. Kind of wondering how RP and EGT compares with other setups.
Somehow I see this leading to me needing that new turbo and sticks
Old Sep 6, 2008 | 10:55 AM
CoolumConst's Avatar
I am ordering an mp-8 to run with mine.
Old Sep 6, 2008 | 12:49 PM
SINGLESTACK's Avatar
I am stacking a tst with mine and it works great.
Old Sep 6, 2008 | 12:55 PM
goose2w1's Avatar
Quad Race X2 and no plans on switching. I run my Smarty on 7, RP2, TM2, TQ3, Shirft defuel on, and wastegate off. I will run the X2 on 1 when in town and 2 on the highway. It takes work, but I can get into the mid 1400's with EGT's. I also get about 21ish MPG highway, and rail pressure will stay around 24-25K at WOT easily.
Old Sep 6, 2008 | 01:00 PM
Nate-03 D's Avatar
Smarty JR and a Dr.Performance Stage ll box
I don't know if it's the Smarty or what but the truck has GREAT top end power. 70-110mph comes real fast.
Old Sep 6, 2008 | 02:01 PM
rip 112's Avatar
Love my Mp-8, great stack with Smartys.
Old Sep 6, 2008 | 03:00 PM
Sniper05's Avatar
I have heard alot of good things about the MP-8, so i'm ordering one pretty soon, i have also heard good things about the Edge EZ, i here they stack rather well to! Good luck!
Old Sep 6, 2008 | 03:24 PM
Bswope's Avatar
TST here but might give a MP8 a shot!
Old Sep 6, 2008 | 05:53 PM
twoforme2's Avatar
I use the EZ with mine, and it does not give any problems at all. Although with EZ on HIGH and Smarty on 5 I does not quite have enough air to cool and EGT's just keep climbing at WOT. At WOT it still blows a little black...guess it is time for a bigger turbo.
Old Sep 6, 2008 | 06:46 PM
rstone's Avatar
does the mp-8 do boost fooling
Old Sep 6, 2008 | 06:49 PM
rstone's Avatar
I am looking for a good stack to would get more out of ts mp-8 or a set of 50hp injectors
Old Sep 6, 2008 | 06:54 PM
rip 112's Avatar
Yes it does boost fooling. I believe the Smarty does also.
Old Sep 6, 2008 | 07:05 PM
mikmaze's Avatar
goose, have you had the timing removed from that box or are you running smarty non timing or running the added timing from both ? heard many folks get the timing taken out of the quad to let the smarty handle the timing. or do you just crank the tunes and not listen to the rattle ??
Old Sep 6, 2008 | 07:46 PM
rstone's Avatar
smarty does it up to 42lb of boost then it throw a overboost code so I need a boost fooler with mine
Old Sep 6, 2008 | 11:08 PM
Spooler's Avatar
I have a Quad II with the pressure only tune loaded. Works great. Not as adjustable as an MP8 but it doesn't have a rail gauge, temp gauge, or boost gauge either.
