What Valve Body & Why?
My transmission build is progressing and I need to start looking at valve bodies.....
So far, I bought:
BD Black FlexPlate
Opie Billet Input
Mag Hytech Doulbe Deep Trans Pan
Billet 4.2 Apply Lever
Billet Strut
Billet Front Servo Cover
What valve body should I look at and why?
Do I need all new solenoids/electronics with the new VB?
Are the BD and ATS units junks?
So far, I bought:
BD Black FlexPlate
Opie Billet Input
Billet Strut
i would go with goerend he gives you the new solenoids with the kit you will need the other plug in and the heavy duty gm transducer i believe it is called look on www.transmissioncenter.net i believe it is the website for patc transmissions
and yes im curious to why the 3.8 lever and not the 4.2? thanks
upgrade your servos whiler your at it too, and your bands! dang your going that far might as well do a full rebuild!
what is the stock ratio lever as well is it 3.8?
From doing my own race car trans I would say it has to do with the way dave has is pressures and stuff setup for shift timing/application.
Everybody used to automatically throw a 5.0 lever in their 727's when they used them for performance, but that has changed. If you don't use dave's valve body, i would ask the company that is supplying the valve body. The higher ratio really doesn't = better shifts without know the rest of the build details. I have friends who use the 3.8 levers in race cars and I use the 4.2 in mine (that is what griner recommended since he built the valve body)
hope that helps
Thanks for all the help and info
Anyone know about the GM Governor Solenoid conversion?
Good or bad?
This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions.
http://www.transmissioncenter.org/51...Up_Diagram.htm
http://cgi.ebay.com/ebaymotors/Dodge...item1e5675a5dd
Good or bad?
A 5 to 1 ratio gives an extra 31% torque holding capacity in second gear
Placing one pound of force on the tip of the apply lever causes 5 pounds of force on the band.
12ValverDave
11-15-2008 03:50 PM
Mark Thomas
29
06-13-2006 10:02 PM
midwestdually
24
12-06-2004 08:10 AM
FireNhole
03-14-2003 04:56 PM
