what tire psi for toyo m/t's
Old Nov 6, 2008 | 08:39 PM
roxj's Avatar
i just got a new set of 35 12.50 17 toyo m/t's. what tire psi are you guys running in yours to get the best wear and ride?
Old Nov 6, 2008 | 08:56 PM
tcr's Avatar
tcr
Running 65/55 F/R but I have 20s.
Old Nov 6, 2008 | 09:14 PM
STate's Avatar
I have 285 75s in the AT. 65 frnt 55 rear.
Old Nov 6, 2008 | 11:26 PM
pwknapp's Avatar
I ran 40-42 front and 38 rear in my 35's. Lasted 45k with siping. Went with the 37's this time.
Old Nov 7, 2008 | 06:57 AM
RD TRCTR's Avatar
I've got 285/75 M/T's. I'm running 67 in the front and 53 in the rear.
I recommend using chalk and driving in a straight line a short distance to determine proper pressure for your set up.
Old Nov 7, 2008 | 08:49 AM
CTD Hauler's Avatar
I agree with doing the chalk test. With that said, I ve got my 35's on the stock wheels and have 60 in front and 35 rear. Even at that, the rears still aren't touching the outside lugs when empty.
Ron
Old Nov 7, 2008 | 10:44 AM
Woodchuck61's Avatar
Do the chalk test.
Old Nov 7, 2008 | 10:46 AM
XXLTEXAN's Avatar
65/55 then 65/60 I swear that bumpy back end is giving me some mpgs:-()
Old Nov 7, 2008 | 02:19 PM
CrashCade's Avatar
I run between 37-42 depending on what kind of driving I am going to do. Even at 42psi I still wear the inners down faster then the rest. I am running 37x13.5x20 Nittos, but they are pretty much the same compund.
Old Nov 7, 2008 | 06:39 PM
DirtEater's Avatar
I'm on my second set of Toyo 35" MT's and usually run about 42 in the front and 35 in the rear. Like above, I see more wear in the center even at 42 psi, which would indicate a little too much pressure. However, with the heavy motor up front, I'm not comfortable going down much lower.
Old Nov 7, 2008 | 07:03 PM
kjp's Avatar
kjp
I just put on a set of Pro Comp XAT, could you one of you guys explain the chalk test to me. I am currently running 50F/45R. Thank you in advance.
Old Nov 7, 2008 | 07:13 PM
sid325's Avatar
I have the 295/70/17 MT's and run 65 front and 40 rear(empty). Tire patch is spot on and they're wearing great, 20,000 miles or so.
Sid
Old Nov 7, 2008 | 07:20 PM
STate's Avatar
KJP,
Run a line of chalk across the tread (perpendicular to rotation of tire) Then drive a few feet, making sure to get a few full rotations on the ground, get out and check the chalk mark, if the line is warn in the center only, let some air out, if its warn only on the outside, put some air in. As soon as your able to get even wear across the chalkline, thats the best press. to run.
Old Nov 7, 2008 | 07:39 PM
kjp's Avatar
kjp
STate
I appreciate your explaination, I will give it a try
Old Nov 7, 2008 | 07:54 PM
Danderson's Avatar
My friend just mounted some 35"x18 Toyo Mt's on 9" wide rims. He initially inflated them to 55# but said they rode like rocks. He's since backed them down some. With the 9" wide rim he's got more room to play with.
