what to stack w/ scarry larry?
I 've been running scarry larry for almost a month now. It makes great power, but I would like to stack something with the scarry larry, maybe tst or mp8. Any suggestions?
Lots of people out their go with the mp-8 its almost as common to find someone on dtr pushing the mp-8 as much as they do the smarty. Just make sure it is a pressure only box.
whats an mp-8?? is that a tunner or a chip..also what do u mean by a pressure box.....
MP-8 is a chip or a fuel module as i like to call it. Most tuners or modules do one of two things either timing and duration or pressure meaning rail pressure or a little of both. You kind of want to stack one that does something with something of its counterpart that way they play well together and less parts get damaged you dont want to much timing and detonate the motor or melt the pistons and you dont want to much pressure to crack your injectors blah blah. The MP-8 is a pressure only module whereas the scary larry bullydog is a timing/duration tuner so in theory they should work well together but trucks are all different from one to the next you just got to find that nitch with your own vehicle some work good with some modules and tuners and some dont.
Does the mp8 do boost fooling?
Predator box stack well with crazzy larry, that's what I have
i just learned what trefling was...
brett |
Pressure box....but be careful. Scary Larry has a different pressure ramp down low.
