what size turbo????
what size turbo????
Ok so with what i have in my sig. and i would like to hit around 600hp which turbo should i go with as a single and maybe in the future using it to run a compound system? also i will be adding pressure box, springs, sticks 90's, studs, mod the CP-3, and if you think i need to do more let me know. any help would be great just trying to get a better idea before i go buy one and find out that i should have got a different one.
Thanks,
Thanks,
How do you use your truck? Do you tow, if so how heavy? Is spoolup and strret manners more important that HP? There are lots of choices available but with turbo's everything is a compromise.
The 62mm turbo's by HTT and II would work great with your setup and could be used in a set of moderate size twins further down the road. You can do close to 600 HP but its going to be hot!
Step up to a 64mm turbo (in this case I like the HTT SS 64/71/13. This will get you to the 600 mark with slightly slower spoolup,and a small amount of surging while towing. You could also use this turbo in a twin setup but for what your HP goals are the 62mm in a twin setup would be a much better fit.
Now you could go with a 66mm turbo, sacrifice more spoolup for more topend HP. Surging is an issue while towing until you learn to drive with it.....
Doug
Doug
Doug
Doug
II SPS62 is also a good turbo, since you have a 6-speed lag wont be that bad at all even if you went with a 64mm....The SPS62 is good for 600hp from II but with a little giggle gas 700+ is good!!!
If you are still concerned about lag...then you might want to look at either II PS64 or 66, which will surge a little while towing but will spool very well and help you achieve 600hp....but will be very HOT and DP will be high. But for everyday driving and some towing with a little racing mixed in a 65mm EX wheel would be ideal...
So my votes are...
Not worried too much about lag while hitting 600hp...SPS64
Kinda worried about lag and close to 600hp...SPS62
Really worried about lag and dont mind warm temps...PS64
Afraid of lag and high temps in the 500hp range...PS62
A 65mm wheel will provide the best spool-up but will net higher drive pressures and EGT's
While a 71 wheel will have some lag, DP and EGT's will be way down.
Of course I am only speaking for Industrial products...but I know someone who has a HTT 62/65/13ss and LOVES IT!!!
So my votes are...
I agree with Doug, a 62mm turbo may make 600 hp but it is really gona be too hot to use. To keep 600 hp cool you need at least a 64, or you could run a 62 with some water and that should help a lot.
With just a smarty beta on my truck (before the sticks) I could peg a 1500 degree guage with my SPS 66, and thats a 66/71/14. With the sticks it will actually get a lil hotter now, and I doubt I am at 600 hp and I have a 6spd and im at 800ft elevation.
A 62 may get you there, just dont expect to be able to use the 600hp much cause heat will definatley be an issue.
I tow my boat all the time on lvl 5 REVO and 1000-1100* is all I see and that's while lugging it....my SPS62 can keep me cool all day long!!!
well see that is why i want to get a good Turbo for what i need now and that will also be good in a setup later down the road.i have alot more that needs done before i go twins and the extra cash it would take for the twins i should get everything else up to speed.
62-71-13ss is an awesome turbo but will prob not make 600+ all the time. I have two buddies that run em one on a 305/555 and one on an 06' and they make low 5's with similar equip in your sig...that said it is a great turbo and I want one
