What Next... I need suggestions
I just removed the cat from my 2500, installed a bullydog chip, and changed the air filter. What should I do next. I heard that there are no injectors for the 2006 truks yet is that true???
Fuel pump, Glacier Diesel has good ones. Do you have gauges yet? That is a must if you are running mods. I'm sure that others will chime in with other stuff.
Fill out your sig, too. Go to user CP in the left hand corner of the page. Welcome to the DTR!!! |
I have an '06 and have had Don's Flux injectors on since June! [guitar] [guitar] :cool:
I vote for gauges first, and then a Quadzilla boost fooler. Both are pretty cheap and easy.
Yes you definitely want gauges ASAP!! And also fill in your sig!
Originally Posted by supercharged_hp
(Post 1234700)
yes guages,, get the crazy larry for your bullydog programer,, or others,, smarty seems to be a very popular choice. And then be very prepared for tranny work (if it is an automatic) or clutch (if it is a standard) After that, then turbo,,, and on and on and on.,, we can help you spend money no problem
Kevin |
Originally Posted by morkable
(Post 1234958)
Kevin |
Originally Posted by 2500Diesel
(Post 1234642)
Oh well, first post........newbie [dummy] Anyway,......... removing the muffler and leaving the cat would be better as far as noise and EGTs, right? Also swiss cheesing the airbox if you wanna get some free mods. ...................Jim |
Injectors are out for 2006 trucks. As has been already posted, my suggestion would be this place....
http://www.dynomitediesel.com/ I'm currently a little behind you in the mods department but am planning on some injectors, gauges, and an intake very soon. Been trying to find some more info on this Superchips firefly. I heard I will be able to use the SRT pillar as it comes with a gauge that does EGT and Boost all in one.:D |
Originally Posted by Jim Dynomite
(Post 1234985)
Uhm..........Isn't that suppose to say "I just put the kitty out for the night"?
I vote for some gauges and then a boost fooler.
