What is the K31 in the PDR towing twins?
Old Apr 23, 2008 | 08:09 PM
jmccart's Avatar
What is up with this turbo. I did a search (titles only) for just "k31" and did not find that much. I did read that a k31 does not mean one specific size turbo. What is the scoop?
Thanx.
Old Apr 23, 2008 | 08:12 PM
jmccart's Avatar
I just realized I should have said PDW's II' compounds, the have a sale selling II towing twins. I just did the search and kept reading "PDR."
Old Apr 23, 2008 | 09:11 PM
wap's Avatar
wap
That is what the Aroura 5000 is based off of.
It is very popular in many towing twins and that is what II uses in one of their twin set ups too.
Old Apr 23, 2008 | 09:51 PM
RJ285's Avatar
What highway diesel is that turbo used on if any? I know the s300 comes from a cat 3126.
Old Apr 23, 2008 | 09:52 PM
Bjans's Avatar
its off a 60 series detroit
Old Apr 23, 2008 | 09:56 PM
abc4yew's Avatar
The K31 is a light duty version of an s400 for all intents and purposes. The compressor side is a very efficient CNC machined aluminum turbine.
The Aurora 5000 uses a non-wastegated exhaust housing with an 0.80 A/R
The K31 is a wastegated turbo in stock form with a 1.28 A/R single volute wastegate (at least the one sitting beside me is) and the II towing twins use a Wastegated housing but I'm not sure if it is this size but it could be...The A5000 exhaust housing weighs around 10 pounds the Wastegated one weighs over 30 pounds.
I got mine brand new for $300 on Ebay. A non wastegated housing was $450 including the matching T-4 ATS exhaust manifold....trick.
Old Apr 23, 2008 | 10:03 PM
jmccart's Avatar
Thanx for all the info guys. 30 pounds, that is crazy heavy. Seems like it would rip the bolts out of the bottom of the manifold. Maybe there is a bracket to help with support.
Old Apr 23, 2008 | 11:37 PM
WUnderwood's Avatar
no, usually a single is held without a support bracket, but they are sure heavy
Old Apr 23, 2008 | 11:59 PM
53 willys's Avatar
I would assume it would have a support if it is in a compounds configuration..but I have not seen the II compounds that close myself.
Old Apr 24, 2008 | 01:27 AM
WUnderwood's Avatar
most of the time, the bottom turbo is held up by the hot pipe, but I could be wrong
Old Apr 24, 2008 | 04:25 AM
94ttss's Avatar
I'm running the K31 in my twin setup, here is the bracket.
Old Apr 24, 2008 | 10:17 AM
RJ285's Avatar
What do you mean by A/R? Other than the weight savings, are there any other reasons to go with a A5000 over a stock k31?
Old Apr 25, 2008 | 06:46 AM
wap's Avatar
wap
The a5k will bolt up to your stock manifold, a K31 in stock form will not.
A/R is the area over the radious, IIRC. Basically the bigger the A/R the slower it is gona be to spool and with a factory A/R of 1.28 you would have to be runnin crazy fuel to get it to spool. Thats why the the A5k has a 0.80, and I THINK that is roughly equivilant to a 14cm exhaust housing.
Old Apr 25, 2008 | 08:58 AM
RJ285's Avatar
Good to know. Do you know the A/R of a stock s300? I'm think of trying to switch in to a stock s300.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
usmcdbd
19
Jun 28, 2010 11:15 AM
JSCumms2000
Jul 29, 2008 01:19 PM
Stock 02
28
Sep 24, 2006 11:09 AM
