What does it take to make 500 RWHP with a 3rd gen ?
Old Sep 26, 2007 | 05:52 PM
  #31
JD Dearden's Avatar
Originally Posted by PEAKSTRYDE
Believe what you want but I will post my dyno sheet when I ge home.
Stock fuel system too BTW.
Not doubting your numbers or nothin but dyno numbers really dont mean much the track or an engine dyno are really the only truth.
Old Sep 26, 2007 | 05:55 PM
  #32
rustyshakelford's Avatar
Originally Posted by 82NDSNPR
thanks rusty been wondering where my sis was she was late for her event at the special oylimpics should have known you were in the mix
yeah...i couldnt believe that the special olympics was hiring playmates to coach the kids! she definately got the looks between you two!
Originally Posted by JD Dearden
So is that why you drive a manvan for the wheel chair easy access?
and the days most brutal burn of the day goes to....JD
and thats just how i like it!
brett
Old Sep 26, 2007 | 06:03 PM
  #33
TriSum's Avatar
Demon, could you just add a turbo to yours for a better tow vehicle? Cool things down a little. Is that what the problem was ?? What about the BD Super B+ ??
Mouse- not trying to hi-jack, just trying to get some meaningful info going here.
David
Originally Posted by demon1
i ran 550hp and 1016tq. with my truck with only a smarty a set of 80hp injectors and a fass 150 pusher pump. all on the stuck clutch,cp3 and turbo.
not the most towing friendly set up but it made the numbers.
to get what you want and still have a very drivealbe truck that can tow. i would get a small set of injectors, a sps62 turbo, the new beta smarty, a decent lift pump, and a SBC CON OFE clutch. that will put you at and easy 500hp all day, and with a very reliable rig that still gets great fuel milage and tow like a dream.
Old Sep 26, 2007 | 06:12 PM
  #34
demon1's Avatar
David
to the setup i had then yes with the addition of a turbo that would have been a great towing setup. yes the EGTs were the issuse. also to that setup a clutch would have made things alot better too.
actually the numbers in my sig were from just adding a turbo. since then i have changed to a bigger set of injectors and some other fueling mods i will have new numbers next month.
powermad
21
Sep 16, 2007 07:48 PM
mstordahl
Feb 26, 2007 01:33 PM
Big Blue24
Feb 14, 2007 07:12 PM
quads4_life
36
Nov 7, 2006 06:20 AM
CTD2001
16
Jan 14, 2006 11:34 AM
