What To Do FIRST ! (06)
I don't plan many "mods"; mostly just in to make the truck perform/last (safely) for a long time. ...good clean air and fuel and comfort. I will pull a trailer occasionally, but not much. Got the truck with 156K mi. Thus far have flushed several fluids (Oil myself...not bad); (Coolant..BG flush..wasn't bad); (Trans...BG flush...was very bad); (rear pumpkin...bad); (front pumpkin...not bad); (pwr steering...BG flush...bad). Still need to flush brake fluid and that "extra" transmission reservoir for the 4x4.
Discovered strange code: U1421....I can't clear it with my tool... I know the definition, but don't know what it really means in plain USA English.
Shift kit for-sure! And trans electronics...etc,etc......
I have the triple disc TC; i kinda wish i had a singal disc so it dosnt lock so hard, i still have the stock input shaft; i feel the triple disc should have the HD input... A shift kit with a good single disc low stall TC [Goerend] should be ok if trans pressure is high enough and HP isnt wild
. Driver needs self control!!
A low stall TC makes these trans a lot better for DD and towing!
Not arguing with you John; just throwing my 2$
organicfarmer:
No problem Sir,.....I just wanted to say that I recommended an aftermarket valve body to danalex and if he did that the "shift kit" you mention would be put in that aftermarket valve body. All of the major aftermarket diesel transmission companies (ATS, Suncoast, Goerend, etc.) do major changes internally to their valve bodies.
Anyway, in light of danalex's last reply it looks like he is going to stay "stock"
for now.
organicfarmer (06-14-2016)
1stTimeAround
10-10-2004 04:02 PM
bellyscraper
12-20-2003 01:52 PM
BulletMan
10-31-2003 10:02 AM
