Sponsored by:
Sponsored by: DashLynx
What am I going to break?
Old 03-15-2007, 06:10 PM
DODGE4X4's Avatar
If I run my Edge Juice/ Attitude on level 5 and the low boost adjustment all the way up what am I going to tear up. I have a 6sp so I know I'm fine there but what is the weak spot. I do not do any racing but I do get on it and run it pretty hard.
Thanks,
Old 03-15-2007, 06:12 PM
JD Dearden's Avatar
Nothing for a long time unless you have some bad luck.
Old 03-15-2007, 06:13 PM
35" 05''s Avatar
clutch go bye bye
Old 03-15-2007, 06:17 PM
JD Dearden's Avatar
Originally Posted by 35" 05'
clutch go bye bye
I have a ton more stuff than an Edge box and my stock clutch hung on for 15k and diden't exactly baby it and I pulled 20k with it.
Old 03-15-2007, 06:19 PM
04smoker's Avatar
Oh nothin. Probably just the clutch. No big deal right
Old 03-15-2007, 06:22 PM
JD Dearden's Avatar
Like I said mine hung on fine, and my buddies 06 has 50k on it and he runs the bddl all day. You are probably goin to loose the clutch eventually anyway.
Old 03-15-2007, 06:24 PM
DODGE4X4's Avatar
I had a strong feeling that yall would say clutch,, what about fuel pressure can the fuel pump hang in there?
Old 03-15-2007, 06:31 PM
JD Dearden's Avatar
You could loose that either way, no actually it will kill it dead so just count on it, there no more optimism just count on the entire truck falling apart then you won't be dissapointed.
Old 03-15-2007, 08:20 PM
3500lly's Avatar
With just running the edge your fuel pump will keep up just fine, if you stacked another program with it then it would have a hard time keeping up.
Old 03-15-2007, 09:35 PM
triplenickel's Avatar
Mine slipped on level five on the second day I had it (30,000km on truck).
Old 03-16-2007, 07:55 AM
omaharam's Avatar
Ummm...a clutch should last for 80k+. You say 15k like it's a good thing. Obviouisly the clutch wasn't holding your power and usage.
Old 03-16-2007, 10:04 AM
JD Dearden's Avatar
Oh wow thanks I diden't realize that, I know 15k isn't good but it did hold which shocked me based on what I have done and how I used it.
New2Diesel
02-28-2011 08:28 PM
J Lent
10-07-2009 06:50 PM
Chip
14
06-21-2009 03:59 AM
roughstock
07-08-2006 04:39 PM
Quick Reply: What am I going to break?
