Wastegate BD Twins
Old May 10, 2009 | 07:16 PM
browndg's Avatar
Wastegate BD Twins
Started out with the BD super B single, Upgraded to the towing twins.
question 1, do you need to re-set the waste gate on the super b single in the twin set up. ??
Question # 2,: Dyno the truck made several passes, HP peak 503:tq 1035.
I was hoping to be around 550, what other mods you think I need to get to 550.
Oh, we think we have the 07 defueling issue also.
Old May 10, 2009 | 09:06 PM
UnrulyNFS's Avatar
My truck makes what yours does with only a Smarty Wild program(Haven't dynoed the Revo or TNT-R). In fact, I think my highest with the Smarty slone was 503 exactly. With an MP8, it makes about 530-540. With a TST/Smarty/MP8, it makes about 570 on stock injectors and CP3, but TST settings are key for mine. Changing the TST just by one level can drop as much as 20rwhp, for mine there really is a sweet spot. TST alone is 490-500. TST/MP8 is about 520-530.
Old May 11, 2009 | 04:30 PM
browndg's Avatar
That is impressive, and quite a bit cheaper too.
I'am about ready to pull all this ....it out,sort of frustrating at the very least.
Old May 13, 2009 | 03:12 AM
Snapoff's Avatar
question .......
The towing twins are not really intended to be high perf....600hp is about it. I have made more, but the egt's are extreme and I wouldn't go there.
The R-700 is a far better setup if you are looking for power.
As far as the 07 defueling issue goes I made 830Hp and 1860FTlbs (#2) at 2000 rpm with a blown headgasket and buggered valves...What do you think another 1000rpm and would do????
Peak power comes at about 3000rpm with some 2007 trucks...So what!
The 2007 fuels harder and sooner....I think it is quicker.
Old May 13, 2009 | 03:15 AM
Snapoff's Avatar
You need to talk to someone that really knows their diesel performance stuff....Like Browns Diesel.....Do a search and make a phone call.
Old May 13, 2009 | 03:52 AM
n2moto's Avatar
What is suisun?
Old May 13, 2009 | 10:58 AM
browndg's Avatar
Originally Posted by n2moto
What is suisun?
Suisun City Ca,
Old May 13, 2009 | 11:05 AM
browndg's Avatar
A solid 550 is what I'am looking for, any Idea on how to get there from here ?? Keep in mind I tow at least twice a month 14-K, Max egts is see are around 1200.
Old May 13, 2009 | 12:09 PM
mainiac's Avatar
cp3 upgrade so you can take further advantage of the smarty. then some mild injectors and 600 should be possible. don't forget valve springs and head studs. your real close.
Old May 13, 2009 | 01:49 PM
UnrulyNFS's Avatar
I would say try Flux 1's and an MP8 instead of pressure from the Smarty. Do some head studs while your doing the injectors. No studs, then keep it to 45lbs and less IMO.
Old May 13, 2009 | 03:31 PM
browndg's Avatar
I have 2 reason for trying to steer clear of the injectors, because of the weight of my toy hauler,also the smoke factor, I really do not want more smoke.
I will go with the CPE upgrade and the MP8 and see where that lands me.
Old May 13, 2009 | 03:49 PM
O.T's Avatar
O.T
BD towing twins will make 575 all day long with the correct fueling. Wastegate adjustment can be determined by the egts and smoke. If you are clean and making 55-60psi no need to close it down further.
Old May 13, 2009 | 04:12 PM
browndg's Avatar
I think I really need to look into the Cp3 kit. I think my truck is really defueling, my dyno sheet at 3100 rpm has a drastic drop off. rail pressure is at 25k.
Old May 13, 2009 | 04:19 PM
2007 5.9's Avatar
Don, you need to come back to LCD and re-run with some WG adjustments, MP-8 and a Cp3 mod.
The reason you have the drop off at 3100 is since you dont have springs yet and are ruuning 50+psi, I dont run trucks above redline with out springs. So at 31-3200 I let off, thats why the drop in power.
I think that with somemore time and a pressure box and some WG adjusting we can squeeze some more from your rig....give Erik a call.
Old May 13, 2009 | 04:28 PM
browndg's Avatar
I was waiting on erik to call me back,I'm ready to do it.
