van aaken 3.2/quad standard
Old May 2, 2007 | 12:22 AM
vess33's Avatar
I am going to try out a van aaken 3.2 on my truck and looking for advice. Remove the quad completly or leave it on to add timing and some pressure. If I run both what levels should I run? I am looking for increase in low end with smooth power. I am not drag racing or pulling and try not to launch too hard for the sake of the tranny. I do pull my trailer 1-2 times a month around 8000 lbs or so.
thanks
Old May 2, 2007 | 12:52 AM
CG98x's Avatar
The 3.2 will run hotter than your quad because it does no timing. It is a good box that delivers smooth consistent power but it will run hot especially if stacked with the quad.
Old May 2, 2007 | 03:28 AM
Dodgezilla's Avatar
But it will make some awesome bottom end power while stacked!!!!
Old May 2, 2007 | 06:43 AM
trik396's Avatar
Run it with a programmer that does timing. And let me know how it does because I'm going to be doing the same thing soon....
Old May 2, 2007 | 08:29 AM
stock03's Avatar
I have the C3.2 and I run it on tow mode all the time. I had it stacked with a Ramifier, and it smoked way too much. And yes, the EGT's were out of control.
Graphite600
16
Apr 27, 2005 02:30 PM
Battering Ram
110
Mar 25, 2004 06:14 PM
Original Junior
Jan 15, 2004 12:26 AM
GLMaines
Oct 7, 2003 09:31 PM
Copenhagenjunkie
May 19, 2003 08:04 AM
