valve cover breather
i was just wondering if anybody uses a valve cover breather i know on performance gas motors a lot of guys run them. i was just wondering if it would benefit me or not and if it could cause any problems.
are you thinking of a breather (already has one like XLR8R stated above) or are you thinking crank case evacuation system which is plumbed from the valve cover to the exhaust (or in big race motors they use a vacuum pump) to create negative crank case pressure?
go to o'reillys and get some gorilla glue buy a small k&n filter lke mine then cut the top out of the filter cap put the filter in it with the glue then put the cap back on the truck but make sure that the chrome piece is facing the front of the truck when the cap is tight!
bishgeo
Jul 25, 2010 01:21 PM
signature600
Nov 25, 2007 01:28 PM
