Understanding the Smarty softwares
#2 should be less timing than stock.
So what is default 0? Stock is 1,aftermarket 2, and so on.What is the difference between 0 and 1?I understand 2 thru 4.
What do you guys consider too much timing rattle?I can run timing 2 and hear nothing,run default 0 and I hear a rattle.Nothing excessive but I can hear it.I'm leaving it on 2 until I get a good answer on this.
If you are talking about the REVO, the following applies (straight from the manual):
Injection Timing:
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors ( less timing advance than # 2 )
# 4 - for fuel economy ( more timing advance than level # 2 )
#0 just resets back to the default setting, depending on whether you are running a even-numbered catcher(resets to #1) or odd-numbered catcher(resets to #2) software level.
From highest level to lowest, it should be 4,2,3,1
Injection Timing:
# 0 - Default
# 1 - Stock
I wish I knew what the Beta 4.4 was on level 3 as it was a great daily driver level. Good driving manners and smoke control...
The Revo on 3 did not have the same response I have become used to running 4.4 on level 3. Any ideas what the Beta 4.4 was for settings? I am going to try the Revo TNT on lower levels for my daily driving recipe...
If I can get it close or better than 4.4 on 3 I will leave it..
Injection Timing:
# 0 - Default
# 1 - Stock
Injection Timing:
# 0 - Default
# 1 - Stock
DTR 1st Sergeant
That makes perfect sense to me and is understandable. The TNT Revo is different however. It appears to me that there is no setting that matches the #2 setting of the standard Revo. I with there was. Marco, any chance of an extra timing setting on the TNT? I would like to try a little more since my injectors are fairly small.
We need a good list for each setting stating what it does and when it is intended to be used. This may help some of the confusion on all the timing and other settings.
I see 55+ psi on mine with no boost fooler. I do get an overboost code every once in a while though (even with the WG turned off). It's odd how it doesn't always throw the code at high boost levels, then every so often when I punch it the OB code pops up.
it must have something to do with the older ECM's.
I got the final word from Bob that the Smarty ONLY fools to 44psi. It's not really fooling either since the ECM will let you boost to that number +/- ( more minus ) without setting codes anyway.
A fooler is required to see higher boosts without codes.... on the new trucks anyway.
I was just told by a diesel tech of all people that a little bump in rail psi is good for more mpg. I read on here that any additional rail psi will do damage to the injectors. I set my rail psi to stock in my Revo program. Is he right and would it be safe to run the level above stock rail psi? And what is the difference between the stock and default rail psi setting, I thought Smarty didn't add rail psi until the Revo came about?
