Sponsored by:
Sponsored by: DashLynx
Twins+Washboard Road = Loose Twins
Old 11-24-2016, 02:54 PM
maddog1927's Avatar
I have an early set of Industrial twins. Every time I hit washboard roads top turbo to exhaust manifold loosens up. This set did not come with a lower mount, but one was built mounts to engine where motor mount bolts are, mounts to turbo at oil drain tube. Turbo to exhaust manifold still comes loose, and there is an added problem of leaks at oil drain tube.
What types of mounts have you guys seen? Looking at pictures Industrial and source auto are both drain tube to engine. A prior BD set I had was bottom turbo flange to engine near bell housing.
Considering selling my current set up to someone that street / strip only and get a set that would be good for off road, but so far I’m not impressed with what I’m seeing for lower mounts (Industrial / source).
Otherwise I’ll just have to fab something that meets my needs.
....or go back to single .... but that would be a hard pill to swallow...
rhedahl
07-20-2016 09:51 AM
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
Leaky Gasket
08-14-2008 07:17 AM
Mule Skinner
11-16-2002 06:57 PM
Quick Reply: Twins+Washboard Road = Loose Twins
