Twins and Bypass Filtration
Some twin designs require that you use a remote oil filter. Amsoil makes a combo (one mount, using two filters, one full flow and one bypass) mount so you can have both. This is the set up I use. Then use one of the two plugs at the top of the regular oil filter mount on the engine block to run the lines to the turbo.
I mounted horizontally on the frame under the passenger side front door... had lines made at the hydraulic shop to reach the distance. The only drawback to that location is that I am limited to the ea100 (as opposed to the larger ea110 or ea120) bypass filter due to space. However, it is a wonderful position logistically and very easy to reach to change filters.
I have a fs2500 and bd tow twins and I am using all the ports available on the filter mount. The factory turbo port feeds my primary and one of the 1/8 npt ports feeds the top turbo. Then I used a 1/8 npt 90 deg. fitting, to fit under the coolant line, to feed my bypass filter.
easinc
22
Mar 31, 2011 11:22 PM
MtnTrucker
Oct 29, 2007 11:30 AM
pybyr
0
Aug 1, 2006 10:32 PM
