Twin Turbo build up
Twin Turbo build up
I got a great deal on most of the piping for a set of twins that use a ht3b over a stocker. Here is a link with some pics
http://www.cumminsforum.com/forum/3r...arts-new-2.hml
What I have
Cold pipe between turbos
IC Pipe
Downpipe
External Wastegate and manifold adapter
5 in exhaust clamp
Flange from stock turbo and to 3b for hot pipe (I have to make one)
Stock 04.5 turbo
Air Filter
What I need?
Intake pipe
Oil feed lines
Oil drain lines
Intercooler boots and clamps
Gaskets
HT3B 26 cm?
What else do I need. Can I use the same oil return and tee the two turbos together? Do I need to build a mounting bracket for the 3b or is the hot pipe enought? Is there any special way to setup the external gate?
Thanks for the help guys.
What I have
IC Pipe
Downpipe
5 in exhaust clamp
Stock 04.5 turbo
Air Filter
What I need?
Intake pipe
Oil feed lines
Oil drain lines
Gaskets
HT3B 26 cm?
Ever try'd Source automotive they have some goodies 4 the doityourselfers
http://www.sourceautomotive.biz/inde...id=25&Itemid=1
Another question or two. Does anyone know the OD of the compressor outlet. I dont have a 3b yet but i want to get the cold piping boots ordered. Next question what is everyone using as a gasket for an extrnal wastegate.
raffshore
Dec 21, 2009 10:52 PM
bgilbert
Sep 10, 2008 05:38 PM
1974d2004x4
13
Oct 17, 2007 07:47 AM
BigBlackBeast05
Jul 24, 2005 09:47 PM
