Turbo timer?
Old Nov 12, 2006 | 04:02 PM
overcomer401965's Avatar
Turbo timer?
Who is running turbo timers and what do yall think about them? lookin for one for the 05. Hoping quad might be workin on something for one of his boxes before I buy one.
Old Nov 12, 2006 | 04:32 PM
morkable's Avatar
I personally recommend a timer that works off of egt. Timers are good, but how do you know how much time, with an egt one you set the temp and it figures out the rest, I bought the isspro one from diesel manor
KEvin
Old Nov 12, 2006 | 06:55 PM
Stealth Mode's Avatar
read on the internet on turbo timers..i instaled a geddy timer bought off tech for 50 bucks he paid around 80 off e bady..cheap awesome unit and works fine on my 04...i think bullydog site said that egt's should be around 250F before shut down...i don't have mine set like that tho..just driving around town 1 minute 20 seconds i have it set for..plenty of time there..and my pda says 220 at this time..maybe this will help you and others.. oh, if heavy hauling i would say w/out egt hook up at least 4 minutes maybe less? haven't towed anything heavy lately.. oh crap yes i did was a 25ft boat..gross weight of 9000lbs..shoot i hope my minute and 20 seconds was enough??
Old Nov 12, 2006 | 07:24 PM
Ill check into one that works off of EGTs, didnt know some worked off actual timers. Thanks Guys
Old Nov 12, 2006 | 08:25 PM
morkable's Avatar
The actual shut off temp is nothing above 350 -375, if you try to wait for 250 you will be waiting along time. The only time mine will hit that is when it is -20 here, and even then it takes probably 3 - 4 minutes. That is the problem with just timers,
Kevin
Old Nov 12, 2006 | 08:28 PM
tcb's Avatar
tcb
they sell a really nice timer right here in the DTR store, works great, and an easy install.
tim
Old Nov 12, 2006 | 09:00 PM
madhat's Avatar
Administrator/Jarhead
I've had one from the time that I bought my truck, I have it set for 1 min for normal town driving, and I bump it up to 4-5 if I have been pulling a load/running my truck hard. It has a option to shut off on a pre set EGT, but I have not hooked it up. I like it. The remote starter is nice, too.
Old Nov 12, 2006 | 09:25 PM
Will the Isspro wire into the commander?
Old Nov 12, 2006 | 09:28 PM
bnold's Avatar
I use one thats based on EGTs I have it set for 300 or 5min whichever comes first... I highly recommend
Old Nov 12, 2006 | 09:34 PM
Will certainly be going with one that runs off EGT's.
bnold, what brand is your timer?
Old Nov 12, 2006 | 09:36 PM
morkable's Avatar
Yes you can run it with your exisiting pyro, you just t into the exisiting wires. The ISSPro was the best priced one I could find, and only from dieselmanor.com. they were over 80 bucks less expensive
Kevin
06RAMCTD
Nov 6, 2009 11:35 AM
CTDPower11
Jan 23, 2007 09:29 AM
TripleBquad
13
Nov 20, 2006 02:59 PM
Cumminsdude
22
Apr 16, 2003 09:00 AM
hellotbone
Mar 19, 2003 01:31 AM
