turbo decision
Old May 6, 2007 | 07:37 PM
gus's 03's Avatar
Question turbo decision
trying to decide between just a regular 62/14 and one of the 71 series 62/14's.
is the low drive presure wheel that big of an advantage? or does it make it lagy at low boost. ?
mods are listed im my sig. clutch will be coming @ same time.
future mods: injectors?, snow stage 2?, and of course some sort of pusher pump.
useage: mostly dayly driving, 70/30 stop&go/hwy. i currently dont tow, but plans are for a boat, and a trilor to tow the jeep. so nothing real heavy by most of you alls standards.
or if some one else has sugestions post up.
Old May 6, 2007 | 10:06 PM
morkable's Avatar
I recommend going to a sps or silver 62, work excellent, and great for towing too. I will be able to post how it is in a real race situation after this weekend (im hoping)
Kevin
Old May 6, 2007 | 10:52 PM
03rmk's Avatar
I've had a 71 series 62/14 for a couple of months now and i couldn't be happier with it.Spools pretty good and egts are almost a non-issue. I love a big turbo for tailgaters, can you say smoke screen.
Old May 7, 2007 | 08:01 AM
Agades's Avatar
I will probably get flamed for this
but
its the truth
the 62/14 is ok for light to medium towing
even great for romp'n around empty and making high rpm HP
but
is
ABSOLUTELY WORTHLESS FOR HEAVY TOWING
it doesnt have enough spool at or below 2000 rpm
my stocker will tow heavier loads at lower egt's and get better fuel mileage, just cant romp on it too hard
Old May 7, 2007 | 09:17 AM
tcr's Avatar
tcr
but
its the truth
but
is
What do you consider heavy? I love mine, and I'll tow 10,000+lbs easily, all day w/ no EGT issues. That might just be a baby load to some though. I think the secret is just having enough fuel to spool the larger wheels.
Old May 7, 2007 | 09:44 AM
2whistlers's Avatar
but
its the truth
but
is
Not that harsh, but ditto on my SPS w/ 3.54's. I would think the common rail would spool it a little faster than mine, though.
Old May 7, 2007 | 09:46 AM
ramtd02's Avatar
Thats the ticket there!!!
My SPS62 has no troubles spooling hauling around my 12,000+ lbs 5'ver. No egt problems if i watch what i do and still get good mileage!!!
Jon.
Old May 7, 2007 | 11:40 AM
Agades's Avatar
Im talkin 26,000 cgvw
in overdrive at 60 mph, just maintaining speed the exhaust temps sit at 1250 - stock turbo under same condition sits at 950 degrees
theres just not enough drive pressure at low speeds to give enough boost to keep it cool
wound out tight , high rpms , cools great but money out the tail pipe
Old May 7, 2007 | 11:56 AM
morkable's Avatar
I am around23 24k gcvw, and love my turbo, I have no problems maintaining speed even on the biggest of grades. Been through the rocky mountains with mine, worked awesome
Kevin
Old May 7, 2007 | 10:37 PM
gus's 03's Avatar
i have a gut feeling spooling up shuldnt be a problem...
flat ground, rollin in to it today from about 1k.. by 1200rpm i was making almost 20 lbs on the stock turbo, then the clutch let loose.. oops.
dam i love this beta smarty!
Old May 8, 2007 | 12:37 PM
Agades's Avatar
your 4.10 rears will help
im running 3.73's
keep rpms up when pulling with a 14 exhaust side
I should have gotten a 12cm housing
Dean Snow
Nov 6, 2007 09:14 AM
13ALPHA
Aug 14, 2007 09:04 PM
Grey Goose
Apr 26, 2007 12:02 AM
James Lucas
28
Sep 1, 2003 03:25 PM
bodom
Jun 12, 2003 06:07 PM
