Turbo Bark " how bad is it"
#31
#32
Now this will be different for every different turbo, but on mine with my boost elbow (stock HX-35) partially open, I hear it, and I'm wondering if its not the wastegate opening. (It sounds like it's hitting insulation, so I think it's coming from there). I imagine the HX-40s with boost foolers are doing the same thing, and possibly aftermarket turbos with adjustable wastegates. How far off is my theory?
#33
I think i have what y'all are talking about but i'm not sure, it started happening right after i put my stage 2 afe system on. I hear a like a buff buff sound when my torque converter locks in and i am accelerating pretty hard. It also happens if i'm loading the engine by pulling a trailer up a hill an then letting of i hear the same thing. I took it to a mechanic to se what it was and he said that i was hearing air come back out of the filter. Is this the "turbo bark" that yall are talking about? If so i would like to get a BOV to fix it if somone could send me in the right direction. THANKS ALOT GUYS!
#34
Back to the point and maybe help someone who wants to run a BOV on the street.BTW they are controllable also by an allen set screw on the side of the unit.
Anyway you all might try an Audi dealer,as in TDI DPT,or Garrett did make some street and race models.Not sure how big some of the models made for gas engines are,but mine was a 4 incher as well as the boost tubes and the in and out side of the inter cooler,and I think some of the bigger race models were somewhere in the 4/5+ inch bracket.Gas,diesel,french fry grease,a BOV is a BOV.Makes no difference as hopefully all you have going through there is air.
It's really hard to try and explain all this as it is very complicated and each engine depending on mainly rpms that of course spin the rotors and then there's the horse power issue,compression ratio of your cylinders,intakes,exhaust size,restriction and the list goes on.
But trust me that when I start to do my engine it will be a drag racer and be able to drive on the street.It will have a very large adjustable waste gate to build boost,have a boost controller,a rising rate fuel pump,and all the rest heavy duty internals and that includes a big **** tranny build up.
BTW,most of the external WGs have a spring that can be adjusted up in the engine bay,you know make it stiffer or weaker for street use as well as the bov engine bay adjustments are adjustable to allow less or more pressure to escape.Unually with a good TCI hard shifting auto the bov doesn't even activate as it shifts faster than you can wot a standard shift.Whew don't even use the clutch except to get outa the hole
#35
I was a whole lot tired when I posted up yesterday and was not too clear.Here however is a site you can go to and get a clearer picture of how things work.
www.streetracesonline.com/articles/turbo/b
#36
I just installed a banks high ram intake manifold, and now i havent heard the "bark" anymore. Maybe im just getting use to the noise lol. im still pretty new at this great but expensive hobby. I have another question? when i upgraded my triple dog to 2.4.1 my downloader asked me to recieve a new "flash" from the dealer for my tranny. what's this flash???
#37
#38
Mike
#41
you got that right. automatic with about half throttle it will make the boost gauge needle bang back and forth. not thats barking .
I did it when I first put it on. so when it shifts in OD you better have it floored or barely on the throttle
#43
mine has barked a few times. I only started doing it after I installed my AFE 2 intake. I paid close attention to what conditions cause it and I now avoid them. Hasnt barked since.
#44
my noise i am experiencing is happening when i let off the throttle them jam back on it.
