which turbo with 60hp injectors?
got my new injectors.looking for advice on a new turbo. i tow my skid steer/trailer about a dozen times a year-any other towing is light duty. any insight much appreciated.
Sounds like you haul heavy. A Garret or an Htt 62/65/13ss. Those sticks with the Edge Juice are going to make the EGT's run real hot. I would recommend a Smarty Sr. to replace it with. Juices run real hot with factory sticks, they have mucho injector duration.
I agree, I put the Smarty Jr. on my set-up and it made a HUGE difference in towing EGT's. I still have the stock turbo as well (saving for twins) I think if you swap out the Edge you might be surprised how cool you run.
You have an 03 and a turbo... can't compare that to a 04.5-07, even one with a turbo.. The E J/A runs hot on 04.5-07 trucks.
Sorry, I missed that in his sig..........your right to a point, cause if I remember correctly, the "600" and newer series versions of the Juice eliminated the fuel pressure curves and are solely timing/duration.
CTDowerTN
16
Aug 15, 2018 06:54 PM
njuser1
Apr 6, 2015 11:45 PM
Dex003
18
May 21, 2013 11:04 AM
OldDodgeOwner
Feb 15, 2010 05:20 PM
