Which TSB?
Old Mar 15, 2006 | 08:52 PM
horsepoor68's Avatar
Which TSB?
Down loaded latest Bully dog programV2.2.5. Now it read i need latest tsb from Dodge. Called dealer He doesnt know which tsb is needed.
Old Mar 16, 2006 | 04:25 AM
Dodgezilla's Avatar
Why would you need a TSB performed in order to run a downloader?
Old Mar 16, 2006 | 05:04 PM
Armapoc's Avatar
I posted about this a while back, but with that version of the Triple Dog it will not remove your key cycles from your vehicle if the version on the pup is the same as that on your vehicle. So it's just warning you to go to your dealer and get the newest software update. If you don't have the update it will install it for you, but that basically nulls the capability to keep your key cycles and fuel used. But then again, after that point you have the newest software and therefore your cycles will stop erasing.
Bradleysram
19
May 12, 2009 08:36 AM
twhman
27
Jul 16, 2006 11:36 AM
Adieselbrother
Mar 21, 2005 03:27 PM
dieselnewbie
Nov 3, 2004 08:07 PM
t-15 firefighter
14
Oct 22, 2004 10:10 AM
