Triple dog question
I want to load the crazy larry once i do that do i just plug it in and redownload?
You have to completely un-install the Triple Dog from your truck and then you have to download the Crazy Larry program from Bully Dog's website and then download/install it onto the Triple Dog....after that, you have the Crazy Larry version of the Triple Dog. Then you have to re-install the Triple Dog back onto your truck....
It boosts HP on all 3 settings and of course your Extreme setting is now Crazy Larry....a tire-roasting 230 HP! Woohoo! Just run the lower settings and you can leave your Triple Dog with the Crazy Larry programming... |
crazy larry is very hard on stock trns parts if you have a heavy right foot plan on at least a triple disk and a good high pressure valve body
Originally Posted by Rpainter
(Post 1433845)
Like these guys said, if you have a heavy right foot....better look into some trans upgrades. I'm a pretty conservative driver and run my BullyDog/EZ stack on the lower settings...
So far I havent had any issues....yet! |
Tow/Economy is still 50hp, Performance is still 90hp, and Crazy Larry is 180hp on Dodges. That advertised 230hp is for the Duramax.
Crazy Larry did blow out my flex plate. |
Originally Posted by 973604x4
(Post 1434525)
"Extreme" is more than enough for me, my clutch is holding so far, any 'Larry's" will surely need a new one.
FP drops to 0 or near to it when I punch it, another reason not to use SL, kinda hard to cover up a new fuel pump from the dealer boys! |
Originally Posted by BCSCUMMINS
(Post 1434536)
No just your ECM [laugh] [laugh] [laugh] [laugh] [laugh]
Originally Posted by Fisherguy
(Post 1434745)
