Triple Dog is a "DOG" on low end
Old Feb 14, 2009 | 09:55 PM
redraider2011's Avatar
Originally Posted by mudder500
U need to enable lowend fueling and take torque mangment off. Those 2 make a big difference
turn on low end fueling and say goodbye to the rubbers haha
Old Feb 14, 2009 | 10:00 PM
TORQUE BEAST's Avatar
Exactly correct...this thread will as well if it follows in the same path.
Everybody knows the BEST programmer is the one you own, so lets leave it at that eh?
Well, I own both as well as others in the past and each have their pros and cons. Not here to be part of any programmer war, just help the guy out if I can.
Be careful with the low end fueling and removing torque management, it is hard on trannys even when built. Fuel mileage will suffer too with the low end fueling.
Old Feb 14, 2009 | 10:06 PM
mudder500's Avatar
I got both done. Thats the only way to spool my turbos. As far as the tires. Not an issue unless its wet. Then i just dont drive it. Lol
Old Feb 15, 2009 | 03:57 AM
BigDave12768's Avatar
Becareful of your tranny if you turn those 2 on.
Old Feb 15, 2009 | 06:08 AM
CTD2001's Avatar
I have a manual transmision so i dont think i can turn low end fueling on because its not an option. Torque management is an option, but i skip over that option because it says its for automatics only. If there is a way to turn low end fueling on for a manual transmision i will try it, just not sure how to? Thanks
Old Feb 15, 2009 | 06:17 AM
tcr's Avatar
tcr
Originally Posted by CTD2001
I just installed the triple dog crazy larry tune on my 06 and it is a pig down low, doesnt feel much better then stock. Once it gets to about 55 it sure will take off, but it just takes a while to get to where it will go. Are there any cures for this? Its fast as hell up top, but i rather have the power low and mid range. Debating selling it and trying something else, thanks for the input
I have the same issue w/ my BDTD, at about 1500-1700 rpm it has a power band that causes almost a surging issue and I've found that I couldn't drive around it, low end fueling made it worse. Keep in mind I have an 03 and BD really doesn't perform on our trucks like it does the newer models 04.5+. Whoops, nevermind I'm seeing you have an 06.
Old Feb 15, 2009 | 07:07 AM
tcr's Avatar
tcr
Originally Posted by TORQUE BEAST
he must be talking about the comparision between smarty and bullydog that everyone blew out of purporsion without ever seeing a dyno sheet.
You need to post the results here
Old Feb 15, 2009 | 07:22 AM
CTD2001's Avatar
can low end fueling be turned on with a manual transmision, casue this would help the problem i am having, thanks
Old Feb 15, 2009 | 07:26 AM
Blake Clark's Avatar
Thats what I figured but I run an EJA so I figured my IQ was a little lower than most....
.... On second though, maybe I should start the "Couyons who run an Edge Club" and I could make myself number two... or wait would that be number one.
Not trying to upset anyone, just having a little good natured fun
And for anyone wondering what a couyon is, just ask a Cajun....
Old Feb 15, 2009 | 09:17 AM
I did earlier. Still waiting on the one showing all three with pressure to be emailed to me.
Old Feb 15, 2009 | 09:27 AM
huck25's Avatar
hey fisher guy would you be able to send me your version of crazy larry
email huck25@telus.net it would be muchly appreciated
thanks
Old Feb 15, 2009 | 10:27 AM
yellowhemi's Avatar
On mine, I enabled the feature where it asks "do you want more throttle response" and it will jump on anything from tow setting to Crazy Larry. I can't tell from your sig if you have an auto or a manual trans. Does that comment in your sig line stating 6 shooter mean you have a manual trans?
Old Feb 15, 2009 | 10:56 AM
CTD2001's Avatar
Yeah i have a manual 6 speed tranny, thats why i am wondering if the low end fueling is only for automatics. Thanks for the help
Old Feb 15, 2009 | 03:16 PM
yellowhemi's Avatar
It is only for the auto and man what a difference it makes! My truck is a ball to drive just on Tow/Economy mode.
Old Feb 15, 2009 | 08:03 PM
CTD2001's Avatar
hmm, yeah i wish i was able to enable low end fueling, but when you select whether the truck is auto or manual and i select manual, it does not give me a low end fueling option
