trans temp
so i finally started to wire my autometer phantom trans temp gauge. anyone know what wire goes where? maybe wire from sender on temp then which pos which ground? right now i put them 1 way and the gauge goes all the way down and when i switch em it maxes out
The back of the gauge should be clearly marked. Or check the instruction sheet.
back of gauge will read
+ this is switched power - this is ground s this goes to sender |
is their an actual sender, or just the brass probe?
The brass probe is the temp sender. It's considerably smaller than the pressure senders.
ya, think ill have to mess around with it some more. somethings not right on my end im sure
well i got er done! about 5 mins and a beer later i realized the ground goes on the top post! whoops, but she works good now, time tuh KEEP THE HAMMER DOWN!
