Towing with rear coilovers?
Old Apr 16, 2007 | 06:43 PM
wrangler04's Avatar
I was wondering how much does the rear sag when towing with rear coilovers? I will be towing my Jeep Wrangler which weighs around 4000lbs, plus what ever a flat bed weighs will I be OK or will the cause my springs to permanetly sag? I wont be towing it alot maybe once a month.
Old Apr 16, 2007 | 07:02 PM
rustyshakelford's Avatar
get some firestone ride rites 2299 if you dont want it to sag
brett
Old Apr 16, 2007 | 07:28 PM
wrangler04's Avatar
brett
how do they work with coilovers? I thought they were just for leaf springs
Old Apr 16, 2007 | 07:39 PM
nriver's Avatar
what rear suspension set up are you usnig with rear coil overs on the dodge?
Old Apr 16, 2007 | 07:50 PM
sorry i have no idea about the coil over aspect. a couple years ago i had an expedition with a 4" rancho lift and 33s. it had coils in the rear and yes it did sag when pulling the boat i had back then, but not to bad and it always came to sit normal when i unhooked. the boat was a 23 foot cobalt
brett
Old Apr 16, 2007 | 11:57 PM
Cowhand's Avatar
Depends on your tongue weight and what spring rate you run in the rears.....
If they're quality springs they shouldn't take a set from being compressed.You can run bags, depending on how the rear coil overs are mounted. Won't be cheap though.....I'd stay away from the off the shelf air bag systems. Might as well toss the coil overs at that point, they'll severely limit suspension travel.
Old Apr 17, 2007 | 01:29 PM
wrangler04's Avatar
I will be running the Rock Krawler 8.0 lift. This will be a street queen nothing offroad just towing my Jeep to the trail head.
Old Apr 17, 2007 | 02:39 PM
mudslinger's Avatar
i would hate to steer you the wrong direction, but I don't think that you would have a problem with that weight. I would think a heavier load might get dicey, but I got the same kit with the belief it could handle a single vehicle or moderate size ski boat on a trailer without a problem. Hmm, maybe I'll run a buddys trailer around in the next couple of weeks just to find out...
nriver's Avatar
thinking you will want your rear coils set up in a dual rate system. soft coil for the initial travel, then firm for towing.
I would talk to them or your coilover manufacturer for their sugested setup.
The cool thing about the coil overs is you will be able to change things up as you need. Different springs for differnet applications.
not sure on the air bag, wonder if there is room with the kit.
should be cool when you are done. That and the tounge weight will not be that much with a proper set up trailer. 400-500 lbs. Depends on what else you have in the bed.
CrashCade
Sep 9, 2009 09:28 PM
Easy_C
14
Sep 2, 2008 06:51 PM
twistingawrench
20
Sep 18, 2006 05:15 PM
Trusty Steed
Feb 24, 2004 07:11 AM
