Tow with 135 hp tp 150hp Nozzles?
Old May 22, 2009 | 02:52 PM
Moobesor's Avatar
Curious if I could be able to tow with 135hp to 150hp nozzle upgrade from my DDP 90's?
The DDP 90's are good, but I want a bit more power.
If I get a flux 135hp nozzle will it haze at idle or while driving normal? Will it get too hot while towing if power levels are set low? Could I maybe go even bigger to a 150HP nozzle?
Guess I want the largest nozzle possibly before towing becomes an issue. I do not tow often, maybe 13000 lbs, and for short distances. I also don't want hazing at idle or while cruising down the higway.
Smoke is fine when stepping on it though.
Anyone?
Old May 22, 2009 | 03:40 PM
AH64ID's Avatar
I would stick with the 90's for towing and look for moure fuel from added duration somehow (thou with the TST and Smarty you may be there)
Old May 22, 2009 | 03:47 PM
Rpainter's Avatar
Anyone?
I have pulled a load of scrap to the junk yard. Hit the scales at 15k and my egt's was not too high with my 200 hp sticks and single 66 charger. depends on what you are towing,how far and the amount of control you have with your right foot. Rob If you are worried with egt's a water system might be in order.
6.7L MegaCab
May 5, 2013 09:16 PM
Moobesor
Aug 11, 2008 09:14 AM
Dusty Ratcliff
Feb 19, 2007 09:17 PM
Dusty Ratcliff
Feb 12, 2007 11:38 AM
4x4
Sep 25, 2003 06:23 PM
