Torquing questions
Torquing questions
I am wondering if you can get an accurate torque on nuts using a crow's foot and torque wrench. You can't use a socket because it is the nuts on the hi pressure fuel lines. If this doesn't work how do you all do it. Thanks
a torque wrench is calibrated for a specific length. a crows foot effectively changes the length from the drive to the fastener so the leverage will change which affects the torque applied. now of course the difference will be slight. but if we are talking about a 1" offset when torqueing to 120ft-lbs, it may be 2lbs off, but when torqueing in an inch pound range, 1" offset would be a significant change.
you can negate the offset by mounting the crowsfoot at 90*.
at least that is what we teach here.
Hey #2, what kind of tq wrench do you recomend? I am in the market for an in/lb wrench
jrussell
Oct 9, 2007 07:54 AM
