Torque converter fluid change
Old Jun 4, 2005 | 09:36 AM
Jmac's Avatar
I have never done this before so I'm asking. To do a fluid change do you just drain from the bottom plug and then fill at the top plug until it's full. Exactly how do you get the fluid into the top fill hole
with 53K does this need to be done at all.
and am I getting this thing mixed up the the transfere case.
thanks
Jamie
Moderator move me into the right forum please I wasn't paying attention to where I was.
Old Jun 4, 2005 | 02:20 PM
TexasCTD's Avatar
Jamie,
I believe you are referring to the transfer case. Yes you just drain it from the bottom plug, then the put the bottom plug back in and remove the top plug and refill to the top plug. Real easy.
There is no way to drain the torque converter. I believe it just drains when you drain the tranny fluid.
93dieselZak
Jun 16, 2011 06:10 PM
esde
Nov 1, 2010 05:12 PM
mainer
Jul 17, 2007 07:13 PM
TexasCTD
Apr 13, 2005 09:38 PM
