tips on pulling up boost rod to get back on WG pin (HTT)?
Old 06-10-2008, 07:26 PM
jmccart's Avatar
Hello. Any tips on this? It is hard to get back up. By the way, when it is disconnected, will the flap be closed or open?
Thanx.
jmccart is offline
Old 06-10-2008, 08:55 PM
rip 112's Avatar
The hose can be pulled off the actuator. When you do that, stick a air line on it and pressurize it, it will loosen up. Might need some help, I know its a tight spot.
rip 112 is offline
Old 06-10-2008, 09:00 PM
jmccart's Avatar
Thanx Rip. I am losing light now, might have to wait until morn.
Do you know what the WG does when it is not attached? Does it close down & make boost really low?
Thanx.
jmccart is offline
Old 06-10-2008, 09:06 PM
flap will blow open and be undrivable. The best thing to do is what Rick said and blow some compressed regulated air into the hose. It will cause the diaphragm to move in the actuator and make it easier to get the rod back on the flap.
lmills is offline
Old 06-10-2008, 09:09 PM
jmccart's Avatar
Thanx l-mill-er time.
(I bet you never heard that one before)
jmccart is offline
Old 06-11-2008, 09:29 AM
CoolumConst's Avatar
Do you have to take the rod off the wastegate to turn the rod. I thought you could just turn the nut.
CoolumConst is offline
Old 06-11-2008, 10:44 AM
Billy Ram's Avatar
The old style like I have you have to remove the rod end from the w/g actuator to be able to turn it in to increase boost. Almost imposable to do with out compressed air. I also like to run a adjustable boost elbow. Something HTT didn't used to sell.
Billy Ram is offline
jmccart
06-11-2008 09:18 AM
O.T
16
01-14-2008 02:47 PM
Bobcat698
11-08-2006 11:20 AM
mhuppertz
09-17-2005 05:15 PM
Quick Reply: tips on pulling up boost rod to get back on WG pin (HTT)?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
