thoughts on Commander?
Yes it is a gauge system and runs other chips if wanted but my issues with it in the past was that the boost would only read up to 44psi they may have a new download to fix that now but not sure, and I ordered several fuel psi kits but none ever worked, but it did read egt and boost but just to 44PSI
my commander failed within thirty days they repaired it and while i was waiting for it to come back i started reading the failures of the fuel pressure transducers the pulsing of the cp3 was tearing them up we mounted ours on the fire wall and connected it up with a snubber attached , now has 50,000 on it no failures
I thought the Commander was very cheaply made. The wiring harness left much to be desired. I powered it up to check out the features and promptly sold it. Never installed it on the truck. That was a long time ago though. They may be better now. I like the Outlook much better, though their quality can be shotty as well.
I started out 2 years or so ago w/the commander for maybe a week. . .well you can see from my sig what I have now for guages.
Mine's been virtually trouble free...I went ahead and hard wired everything rather than keeping the t-clamps that are sent with the unit. They kept losing connection or something and it wouldn't read right. After I wired it in myself it has worked flawlessly. The transmission temp gets squirrely every once in awhile...it'll just read 100 when I know it shouldn't be. But then the next day it'll read normally. I need to call them about that I suppose as I'm not really sure why it would do that. Overall I like the unit and it was a very simple install. Not a bad price either when I bought it...
ive had mine for almost 2 years and its worked well,i also have the old skool fuel pres and it seems acurate,its easy to see even in the sun and i like the fact i can setup the configuration of the display,i would like to see a color option for the backlite though so it would look cooler at nite,i have a scangauge 2 and it has many colors and looks much beter at nite,but all in all i like the camnader,most people that see it think its a xm radio thingy haha
stock03
Nov 9, 2006 11:27 PM
cliff-1972
0
Oct 13, 2002 04:04 PM
