Superchips, tire chnge option not present?
Old Jun 4, 2007 | 08:04 PM
jmccart's Avatar
Superchips, tire change option not present?
Hello. I put new 35'' tires on today. I went from:
Performance tuning (1)
to
change setup (2)
to
only power level avaliable? (3)
According to the book, the 3rd option should be Power level or Options. There was no Options avaliable, only Power level.
Help, ideas?
Thanx.
Old Jun 4, 2007 | 08:28 PM
rustyshakelford's Avatar
sell it and get a smarty....
j/k well not really....
IIRC you have to have a power level selected, then scroll down to options...well thats not much help as youve already done that. well bud im of zero help on this one. its been to long since i messed with one. have you tried the flashpaq forum. theres usually some people hangin out there that could help??
brett
Old Jun 4, 2007 | 08:36 PM
pooperscooper's Avatar
Have you updated it with the recent update?
Procedure as follows.
Change setup
power level
then choose the power level you want
then go to options
then tire size
then select the ACTUAL TIRE SIZE...measured with a tapemeasure
hope that helps
Old Jun 4, 2007 | 09:30 PM
tbarbee1's Avatar
Change setup
power level
then go to options
then tire size
hope that helps
Thats how mine works too. Well I wouldn't say it works but those are the right steps. Does any of you guys high idle feature work?? Mine will not work on my 6spd "I knew it wouldnt" or my wifes 03 auto?????
Old Jun 4, 2007 | 10:05 PM
jmccart's Avatar
Change setup
power level
then go to options
then tire size
hope that helps
Thanx Scooper. Going to try it now. I will report back.
Old Jun 4, 2007 | 10:08 PM
it will work on your 6speed, ground pin 22 on your ecm. mine works.
Old Jun 4, 2007 | 10:24 PM
tbarbee1's Avatar
I will try it but I think its an internal prob with the tuner since it wont work on the auto? Any suggestions?
Old Jun 5, 2007 | 12:53 AM
06 or 07 auto correct? before that it is a no go.
Old Jun 5, 2007 | 01:03 AM
jmccart's Avatar
OK, that worked. With the Toyo 315's that I measured at 34'' I am at like 71 mph turning 2000RPM's. Thanx guys.
I enabled my high idle. There are steps on the DTR here, with photos, that helped my ground the pin. It is easy, a $15 Cummins part and 15 minutes.
RamWheelsBy4
15
Dec 31, 2007 11:58 AM
zulusafari
May 27, 2007 10:52 AM
HOdiesel80
Mar 22, 2007 12:19 PM
Patrick Campbell
Jul 29, 2005 03:31 PM
