Stacking chips
I want to double stack my Edge EZ with another chip, but I need it to be easy to turn off because I tow every day, sometimes very heavy. Any suggestions? :confused:
Get an adjustable chip and you'll be fine. TST PMCR comes to mind.
JAF, Your going to want to put a set of guages in before stacking. It's probably a good idea for some now that you tow with your EZ.
l really like my VA C3.2, It's great for fun value. I do tow with it on 50% and the EZ, but I only tow #8000 and if your not careful, she can get hot. You'll be able to fog out any intersection with both turned up, but you can't hold it like that for too long, EGT's get pretty warm, unless you drop a bigger turbo in. It has a small 3 position toggle that can be put to 0%, 50%, 100% Hope this helps:) |
I dont know about the EZ for the 2003, but my 04.5 600 EZ is stacked with my Juice/Attitude. Not an option for you as I understand the 2003-2004 Juice/Attitude does fuel pressure also, essentially has an EZ programmed in already.
The thing I dont like about my EZ is that there is no way to turn it off. I have the 3 position swith for adjusting levels, but no switch position to completely turn off. I have to disconnect it to turn it off. This is irritating. |
| All times are GMT -5. The time now is 07:24 AM. |
