stacking chips
Please fill in your sig so we can see what you have. This helps others help you.
You can stack the quad with the smarty, just be sure you are using a pressure only tune.
Not sure what you are asking on adjusting "tw".
If you goto the MADS website, it will explain all.
On the opening screen after plugging in, use the adjust options portion of the menu to adjust torque management, timing, rpm limit, wastegate, shift defuel and pressure.
After that go to the screen that allows you to change the sw.
Again, go to MADS website first and take the time to fully understand what these options do before plugging them in.
Good luck!
Good luck!
acook
Jul 30, 2006 03:17 PM
