SRT-10 Start button install
Just finished reading the couple of post from Tommygun and other folks who have done this
install. Seems eazy enough until you try and shut down a couple of circuits. For the folks that just wired it in and did not worry about the other circuits, have you had any problems from the radio, power windows, and other ACC componets? Secondly for folks that did install the relays to protect the ACC circuits how did you do it? |
I didn't not install any relays and I've used the button pretty much every time I get in my truck and have had no problems.
Do yall have pictures of the install?
powerstrokethis,
I hope to have the install done this weekend and can submit photos. |
I don't have pix of my install sinc it was as simple as removing cig lighter, connecting 4 wires and plug it in...
I got to ask, did it come with instructions, and what may I ask did it cost? I might want to try this.
Here's mine... http://cgi.ebay.com/ebaymotors/ws/eB...tem=7924135163
The instructions it comes with basically just siad what wires are needed and where to plug them in. Since mine is lighted, there's one modual for the actual starting (tap intoyellow for starter and key hot to start) and the other module is to illuminate it (ground and power source... I tapped into wiring for dome lights so it dims). |
Mark,
Purchased the start button from Rockwall Dodge $44.32 including tax. All I got was the start button no instructions from Mopar. I am going to try this mod over the weekend, and will post my results. Give me call if you want to check it out. |
Well Started the SRT-10 conversion today. So far the hardest part of the whole thing has been mounting the button. The switch is held in place by two screws that go onto the middle beazle, on or trucks the molding does not incorporate the switch mount. So I am trying to epoxy two plactic 5/8 inch long rods to the beazle. Then I will drill a poilt hole for the mounting screws. Hope this works, because the only alturnitive is the buy the SRT-10 beazle for around $250.00. If it comes to that this BOMB will be scraped. I will hopfully finish on Sunday and can post results.
I didn't have that trouble with mine... it's built to go in the cig lighter so it fits right in and locks into place.
Bubba-CTD,
Did you use the SRT-10 switch or another aftermarket product. The SRT-10 button does go where the cig. lighter goes, however there are no molded post the screw the mountsing screws into. |
No, that's what I was saying.. I use an Ignited Push Start button on mine since I wanted mine to light up. There are a couple pix in my gallery so you can see what mine looks like.
I'm not sure where the SRT-10 goes into... I would have thought the cig lighter as well since that's where it is in the truck, but I guess it has a different dash bezel on the SRT-10 then the others do and that's why it does not directly mount into it. I'll look and see if I can find the little instructions that came with mine... but dont' cross your fingers since I have stuff all over my house and the shop. |
Got the SRT-10 button completly installed this weekend. I will post pix of it in my member photos soon. Don't have a digital camera so have to get film burt to cd before I can post them. Pretty fun mod. and adds cool factor during start-up:D
Yea, it defintaly gives it that cool factor at startup and on mine when I open the doors as well. :)
