southbend clutch
southbend clutch
all right guys my stock clutch is fixing to take a dump on me. its really not liking the performance setting on the bdtd with the 285's. so i'm going to get a southbend because i don't see any point in wasting my money. as of right now i plan on getting the SBC DD 3250 Street which is a 600hp dual disk clutch. my goal is to eventually get to 550 rwhp. i also tow pretty regular. what do y'all think? am i going to have any problems with slipping or wearing with it? Thanks
Ross
by the way i don't know anything about performance clutches.
Ross
If u wanna dual disk that one is gonna do ya fine, make sure u get the sprung hub DD3250! U shouldnt have any issue with slipping or wearing with that setup. Might take alittle to get use to! Just my $.02
am i going to have to upgrade the hydraulics? if so what all does that involve?
sorry it takes so long to get back. for some reason my computer at home won't lemme on here so i have to wait til i go to work.
I think that SB recomends upgrading the hydros on that model. Upgrading the hydros is a pretty simple process. 2 bolts hold the slave cylinder in. And then just pull the clutch master cylinder outta the firewall. As far as mounting the resevoir I just zip tied them to the ac lines instead of drilling into the firewall. Overall the installation took me less than an hour doing it by myself.
Mine's holding up so far quite well running 'extreme'.
oh yeah no crazy larry
Last edited by gafirefighter; Dec 15, 2007 at 06:26 PM. Reason: forgot to add that i don't have crazy larry
Well I think I was in your position about 1 year ago...
There is give and take on certain clutch set-ups. A stock single disk is set-up to be very divable, sacraficing wear for easy of use.
The SBC singles use special material to make their clutches grab quicker and overall wear slower than the stock. The cost of doing business with the SBC singles is they tend to be grabby, but some learning can help to mitigate those issues.
The SBC dual disk is set-up for high horsepower applications with a little more sacrafice in drivability. They are designed to hold lots of power, but the cost of doing business is the cost, upgraded hydros (more cost), rattling noise, esp noticable in the G-56s more so than in the NV 5600, and extra pedal pressure. Talking to most the quality of these clutches are excellent, but you do pay for it.
I have had both the 3600 and the 3250 DD. Honestly they hold great. There is a learning curve trying to back a heavy trailer with the clutch, as well as a little difference in clutching. First/second is sometimes sticky to get into gear. The clutch hasn't slipped with my 35s and the Smarty on Level 9. However, the rattling takes some getting used to. First DD I had was extremely loud, enough where some thought there was something wrong with the truck. The second DD is quieter, but still rattles. It can be fixed with the Fluid Ampr, but for an extra $500 I am holding off, for now...
For the rhosepower you are talking about the singles will hold fine, but if you want that extra step of insurance and pay some more money, than the Dual Disk is for you. Of course, like I said with every step there seems to be a cost, but SBC has done a good job of creating some great options for these trucks. Hope it helps,
