smoke switch?
Old Oct 23, 2008 | 03:17 PM
phantom 309's Avatar
smoke switch?
i just heard about some people that have smoke switches on their trucks. i think it basically just shuts off the turbo? does it cause in problems to a truck and is there anything special you need to install one?
Old Oct 23, 2008 | 03:21 PM
Sam Turner2's Avatar
There is a smoke switch that tells the computer yoru at full boost and it freaks out and dumps more fuel. It works awesome and makes the turbo spool super fast, but I'm pretty sure doing it on a stock truck will just throw codes. Its a common mod to quadzilla chips.
Old Oct 23, 2008 | 08:02 PM
450r's Avatar
the switch will only smoke from like a take off where you have no boost up until you make enough to clear it out but it def makes it take off alot faster if you push it when taking off it will make tires break loose on just the 60 hp setting
Old Oct 23, 2008 | 10:20 PM
Thats true, with mine on 100, I can flip the switch and floor it and break the tires loose going 30MPH with 35's and a flatbed.
Old Oct 26, 2008 | 11:24 PM
wow
so what all programmers can you do this with?
Old Oct 26, 2008 | 11:37 PM
05CTDN8's Avatar
Mainly the Quadzilla boxes and the Edge EZ
Old Oct 27, 2008 | 07:43 AM
06MegaCTD's Avatar
And found out the powerpuck does work also, did it myself a couple of days ago. Works like a champ
Old Oct 27, 2008 | 07:58 AM
matego's Avatar
madhat's monkey boy...
Any chip that plugs into the MAP sensor will work. TST, MP-8, Edge Juice/EZ, Quad, etc. etc. Without a box, it will just cause a CEL and defuel.
Old Oct 27, 2008 | 08:30 AM
WhozNxtLS1's Avatar
Hmmmm...wouldnt work with a smarty jr and a boost fooler huh
Old Oct 27, 2008 | 08:37 AM
kyncl's Avatar
would this help eliminate the so called torque management?
Old Oct 27, 2008 | 09:02 AM
#2 only's Avatar
No, the boost fooler will tell the ecm that your boost is at a safe , lower boost than actual,thus fueling more = higher than stock boost.
With a module and smoke switch, it'll see really high boost,then the module will dump alot more fuel without the ecm seeing out of range boost values,thus no cel.
Old Oct 27, 2008 | 11:25 AM
06MegaCTD's Avatar
yeah and its good to put a 10ohm resistor inline just so the ecm doesn't see absolute high boost and only sends like a 4.8v to the ecm instead of the full 5v. Keeps my check engine light from coming on if say i was to keep it on longer than like 1 minute.
Old Oct 27, 2008 | 01:57 PM
ive got a predator by dr performance. would that work?
Old Oct 27, 2008 | 02:22 PM
It won't my lady left mine on one day driving around town, she called me crying when it wouldn't start (truck won't start if the switch is fliped) She had just fliped it and forgot. She said she drove around atleast 10 minuts with it on.
Old Oct 27, 2008 | 10:09 PM
it plugs into both the map and the boost sensor
