Smoke switch for 06 dodge
?Smoke switch for 06 dodge?
Exactly what wires do I need to tap into to create this smoke switch I've heard so much about. I have the edge with attitude. Do I need the stage 6?
ok the wires are located on the driver side of the head. I crossed the wires with a switch. I threw the switch got black smoke and now my check engine light is on. WHAT HAPPENED? The switch was only on for 10 seconds. Now I barely have enough power to make it home. What did I do to my truck?
Try the battery disconnect trick mentioned above, should work...
Guys, a member is concerned about his truck, has an issue....we're on this forum to help each other, learn, and bomb out trucks (it's not the chevy / ford forums)......you can hug trees and chastize later...and dont get me wrong, i'm not a big smoke fan either
Barryn
Jul 14, 2008 09:30 AM
redramnc
Mar 28, 2005 06:58 AM
