Smarty tuning questions.....
Let me start off by saying that all the differant settings on the Sr. have me a little nervous but with a little help from you guys i should be in great shape...Thanks in Advance so here is the question:
What would be a good place to start for mileage/seat-o-the pants meter on the Sr. with Revo tunes? I am not sure where to start & have read on here that you can really tear your tranny up if you TM is not set properly. I dont feel like spending any more $$ on my tranny @ this point in time. Also, would it be ok to haul lighter loads say in the 5-7k range. Thanks again for any advice in getting this set-up properly.
To save the tranny don't go over 1 or 2 on the TM (torque management) setting.
For best mileage, go with highest timing you can run. As far as the power level settings, it is different truck to truck. I have always had my best mileage between sw 5-7 on most smarty tunes. But that is just me, others report sw 1... sw9... get the picture?
You can run whatever load you like if you are not mashing the pedal hard all the time!
is TM 1 less torque management( closer to factory setting ) than 2 or is it the other way around... i have read some posts saying the numerically the #`s are backwards ...ie. 1 is more 3 is less type of thing.
Thanks
Thanks
BIGDAN65
Feb 18, 2009 05:43 PM
nottanuff03
Jan 13, 2009 09:33 AM
mainiac
Oct 15, 2008 09:35 AM
MegaCabRam
Aug 8, 2008 02:01 PM
Bswope
May 5, 2008 05:53 PM
