Smarty programmer with Edge monitor?
Do you guys know if it is possible to run the Smarty and hook up the Edge basic monitor set up so I can view EGT's, Trans Temp and Boost??? Any of you doing this? If not what monitor do you recommend for the Smarty?
DO you mean the edge insight or the attitude monitor? The insight is a stand alone monitor that simply plugs into the obd port under the dash whereas the attitude is in conjunction with the juice module. and it is pluged in via map sensor wiring under the hood. You can use either one with the smarty just as gauges ( if you set the juice to 0 ) I run the smarty with the edge insight monitor, and it is a nice, clean setup.
Yeah that is exactly what I was thinking of doing. I am really glad you understood my question? The diesel tuner thing is new to me, and I still don't really understand how different units can be stacked with one another without issues. I'm a little hesitant to do that. I plan on using the edge insight with the smarty. How do you like your set up? Does it come with all the hook ups to read egt's, boost and trans temp?
I don't know for sure on that. The Juice with Attitude I installed was for 06-07. 04.5 might be different.
If you are just programming a tune into the truck with the Smarty. I believe after you program it, the Smarty is removed, and you can plug the Insight back in for the guages.
I've never used a Smarty, so I can't say for certain though...
Torque master
Sep 26, 2008 03:24 PM
skindaddy
Oct 30, 2007 04:02 PM
nitis
Feb 26, 2007 07:38 PM
Townsend600
Dec 15, 2006 07:47 PM
chrismez
Sep 26, 2005 01:47 PM
