smarty jr + xzt OR MM3
quad's xzt is pretty much just increasing rail pressure and boost fooling, correct?
any use for it or the 'mileage max' option after you have a smarty jr?
Greg
Greg
Those that stack the XZT with smarty Usually have the XZT pressure only tune. If you have the XZT II you can just download the pressure only tune from Quad. If you have the orginal XZT you use to be able to send the XZT back to Quad for the pressure only.
You could try the XZT with the Smarty but reduce timing on the Smarty. Becareful because the XZT does effect timing.
sCreamin400
Nov 2, 2008 01:46 PM
sootindiesel
13
Mar 27, 2007 10:18 PM
tristan21
14
Mar 26, 2007 11:57 PM
Sixpack73
Mar 8, 2007 08:18 PM
