Smarty Jr. or Quad X2 for an 03?
Old Dec 28, 2007 | 08:12 PM
VaultRam's Avatar
What are peoples opinion on both for an 03 SO. I know the X2 has had some problems but I'm sure that's with the 325 engines only. Thanks for the info!
Old Dec 28, 2007 | 08:16 PM
CrazyFloyd's Avatar
I have no complaints with my x2. Truck runs better than ever.
Old Dec 28, 2007 | 09:24 PM
Buffalo's Avatar
I don't know how true this is but, I read (TDR, I believe) that the SO REALLY responds to the Smarty Jr. Aparently, it raises the HP levels to those of the HO, then adds more power, like on an HO.
I just installed my Smarty Jr. on my '03 HO & really like it. I replaced a Van Aaken C-3.2 (duration-only) box, with it. On my truck, the Smarty Jr. 100 HP level is more powerful than the VA was on the 130 HP level. It pulls harder at lower rpm levels, also.
I'm very pleased with the Smarty Jr. & would buy it again.
Is the other box, you mentioned, a pressure-only box? If so, & if it makes a lot of power, It may not be too good for your injectors. A small amount of pressure is OK but, too much can damage injectors.
A small amount of pressure, stacked with a Smarty Jr. is supposed to be a great combination.
Joe F.(Buffalo)
Old Dec 28, 2007 | 10:34 PM
VaultRam's Avatar
I can't remember off the top of my head but I believe its a combo of timing, duration and pressure but is also updateable via the web and can make it pressure only! I'm really torn between the two although ones a programmer and the other is a box?
Old Dec 28, 2007 | 10:39 PM
AH64ID's Avatar
Just put a smarty Jr in my truck... mild increase, safe limits, lower EGTs and untraceable.
89dieselkong
Jul 27, 2010 10:55 AM
P.J
Oct 13, 2006 01:54 PM
hllbllyhellion
Aug 19, 2006 06:18 AM
bnold
39
Jun 4, 2006 08:21 AM
