Smarty 4.4 4.2 Tunes Needed!!!!
Who do i need to get ahold of to get these tunes? I switch to the Smarty took the PMT off! I want the HOT tunes for the track just need some HELP! Can some one send them to me. Thanks J,C,
those tunes aren't freely distributed and can only be had through Bob. Without the correct supporting mods though....you likely won't be able to get them. From what i see in your sig.... you have some stuff but, not all the right stuff. That's for Bob to determine though... good luck !
Well i got it! Hang on this thing ROCKs Power seems smoother then the PMT and Temp, drop a BUNCH! No more high temps, for me. Power down low seems different from the PMT with the TQ,man, on. Dont know if i am not use to it just seems different. Smoke is not bad at all cleans right up with the stock turbo and (stock airbox) this is on #9. Cant wait to get my twins put on weather will break soon i hope.
tritont-What mods do i need that you see i dodnt have ? I allways take in good ENFO!
Seems to me you oughta be alright w/ the 4.2 or 4.4(maybe not on #9). I'm willing to bet you are gonna get a reaming from Bob ,though, because of the way you got them.
I think Bob likes you to have springs and running twin turbo's that might be a good investment. With the higher boost you have the more chance you have of a valve coming in contact with a piston. Valve springs are good insurance.
Why did he find a way to get them other than Bob? Bob is always the way to get the tunes. Just be patient (my worst trait) and they will come to yo
Hopefully somebody else isn't distributing those. If that happens then the distributions on faith that they do now will get a lot tighter and less people will be able to partake and enjoy (and help) with the developments.
Everything thru the proper channels!
Chad
Chad
Then valve springs and twins will be done. And the tune did come from Bob. I did not get it form anybody else just to let everybody know. I kow the Boost jumps fast without the MP-8 hooked up. Just tap the pedal and 36+. The twins are Scheid's. What would be good springs for this setup? Do i need to talk to Don about a set? And no i do not have the (TNT) tune wish i did!
Thanks for the ENFO! Keep it coming J,C,
rallydriver
11-01-2008 12:41 PM
modified03
04-14-2008 01:06 PM
CTDowerTN
12-13-2007 12:42 AM
