Smarty
Well, I couldn't take it any longer, so I just bought a SMARTY!
Does anyone know the highest setting I can safely use on a 2003 SO 5-speed with only having a modified air intake and open 4" exhaust?
Level 5 is recommended due to the stock clutch. I tried level 7 and the clutch held up fine, but I didn't like the super sensitive throttle, so I'm running on 5.
Might also think about installing a boost elbow. Doing so will get the boost up into the 30 psi range. Will help lower the EGTs.
MikeyB
MikeyB
Run with timing. The none timing levels are for people running stacked boxes that may also do timing.
I got my adjustable boost elbow off of ebay, for around $20.
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
MikeyB
MikeyB
+1 For level #5, I didn't do the boost elbow and still saw 32psi w/ stock turbo.
