single stack kit?
I have seen kits availiable, but they are way overpriced (yet simple straight forward). Fabbing will save you a lot of money in this area (as I know; I am in the process of gathering the supplies)
they also don't come up in the corner of the bed... the come up right over the exhaust and then run a couple 90* elbows to get the pipe to the corner... which kills one of the great things about a single stack, you still have 4 feet width at the front of the bed
I would think that if you went to a truck dealer or parts center you could do it a lot cheaper. I was just in there getting a block heater plug and noticed they had a 5" stack and it was only 20" long or so and when I get my 5" system installed I am goona go and buy it to put on as a turn down tip they also had one that was about 36" long I was thinking I could also do that and put the tip straight out the back instead of out behind the tire so the rocks don't do as much damage and keeps cleaner?? Can't decide
if you run it up in the corner of the bed you would have to go under the frame
think i got maybe 75$ in my single bought the stack off of ebay for 55$ to my door (got it in 2 days
), got 6 ft of flex, a useless 90* elbow, 4 clamps, and a litlle weldin on the stack and it was done.
3rd gen trucks have to come striaght up into the bed from the exhaust pipe...
i had a 6" bull hauler...its in the closet on the patio now. I got all the parts needed at a Mack truck shop. cost me about $200 getting good clamps and all the elbows. only required welding in 2 places. i'll be getting rid of my stack soon....just couldn't stand not having a toolbox. still have all the good parts needed for the new owner to install it.
thaks guys. yea i guess it will be cheaper to build my own. i have the 5inch bullydog and im wanting to use the 4inch to 5inch section and add a small aeroturbine and then 90 up into the bed. then a straight cut stack level with the cab.
nasty01cummims
Jun 29, 2009 09:59 PM
dodge_24
Dec 6, 2008 10:37 AM
53 willys
80
Oct 3, 2008 09:50 PM
SilverHoss99
Feb 15, 2006 05:59 PM
