Show me pics of trucks w/ wheels and tires but NO LIFTS!
Old Apr 9, 2007 | 07:26 PM
wreedCTD's Avatar
Old Apr 9, 2007 | 07:27 PM
wreedCTD's Avatar
Going to add wheels and tires to my rig but NO LIFT, I think i am going to go with 305/70R17s.
Luvnacumns's Avatar
That was before the leveling kit..
Shane
Old Apr 9, 2007 | 07:28 PM
wreedCTD's Avatar
wheel and tire specs would be cool also, in case i see come i like
Old Apr 9, 2007 | 07:44 PM
morkable's Avatar
here is mine
Kevin
Old Apr 9, 2007 | 07:45 PM
wreedCTD's Avatar
Kevin, what are the wheel and tire specs?
Old Apr 9, 2007 | 08:34 PM
67guzzler's Avatar
Here's with 315/70-17D Coopers:
Slight rubbing on the front traction bars (is that the right part name?) when turning close to full lock either way. Easy to avoid except when making U-Turns...
Otherwise, no problems. Mounted on the stock rims too.... 20k miles and still 3/4 tread left and wearing perfectly. 50 lbs in the front and 35 in the rear -- except when towing. REALLY softened up the ride.
Old Apr 9, 2007 | 08:50 PM
RamWheelsBy4's Avatar
This is mine after I removed the lift and lowered the rear. Went from 2" leveled and 315s to stock level front and lowered rear and Power Wagon wheels and 285s.
Old Apr 9, 2007 | 09:39 PM
pro puller's Avatar
No lift with 33" tires
Attached Thumbnails Show me pics of trucks w/ wheels and tires but NO LIFTS!-casper-015.jpg
Old Apr 9, 2007 | 10:19 PM
ptgarcia's Avatar
Originally Posted by PatriotBlu
Slight rubbing on the front traction bars (is that the right part name?)......
PatriotBlu,
You're refering to the upper control arms.
Old Apr 9, 2007 | 10:23 PM
RAT_03's Avatar
DTR's "Secret Agent"
Old Apr 9, 2007 | 11:09 PM
dodgezilla04's Avatar
[IMG][/IMG]
17X9 wheels. 295/70 17 tires
Old Apr 9, 2007 | 11:24 PM
67guzzler's Avatar
Thumbs up
Originally Posted by ptgarcia
PatriotBlu,
Thanks Pauly!!!
So that's the bar that the rear of the tire hits when turned in that side's direction? For instance, when turning right, the inside rear of the right tire hits that bar on my 4x4. It's a soft rub and I've only done it a few times.
Problem comes in when a valet or a porter at the dealer wants to drive...
What's the best fix -- a lift? Spacer? Smaller tires
Old Apr 10, 2007 | 02:42 AM
morkable's Avatar
Sorry about that, they are eagle alloys 0836 rims 20 x 8.5 +25 mm offset. the tires are falken stz4 305 50 20, No rubbing whatsoever.
Kevin
Old Apr 10, 2007 | 02:44 AM
morkable's Avatar
Jay, if you put in a 2 " leveling kit it will fix it right up,, no problems,, just have to get a wheel alignment when done, and have the tech advance the castor to max
kevin
May 29, 2009 10:24 PM
Txwelder
Jan 21, 2007 11:00 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Bobcat698
Apr 14, 2006 03:29 PM
Gary C
27
Mar 11, 2004 07:42 PM
