Savin' pennies for TST
From: From Texas; Staioned in WA; Transplanted to AZ
I'll be damned... it is all plug and play. I guess you take the stock A and B connectors, plug A into C and D into B and it's all good.
Couple quick questions though... one is labeled as the front injector and another is the rearinjector, but what about the one in the middle?
Also... I see the Pyro Probe for the EGT, but what's the Boost measured by? and lastly... you don't have those two if you get the box without the gauges right... everything else is the same?
I am a little concerned about the 04.5 600 install related to the wastegate. Looks like you disable the electronic controls and go back to a manual wastegate setup. This looks like it would take me a little while to do. Also looks like wastegate control tubes running under engine. Makes it a little harder to put on and take off.
I just had an injector replaced under warranty so I do worry about such things for now.
dieselminded
Jul 12, 2004 06:49 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
